95 wolverine/dynojet kit ?
Old Feb 8, 2000 | 10:00 PM
sparkys's Avatar
I have a 95 wolverine which uses a different carb than all the rest. It has a 36mm mechanical flatslide carb. I tried to install a dynojet kit with no success. With the kit in, the bike was so lean it would hesitate and almost put you over the handlebars when you pin the throttle. I removed the kit completely but would like to know what was wrong . Me or Dynojet? I think the latter.I think the jets aren't calibrated right in this kit. If any of you have installed this kit in a 95 please tell me what combination you are using. Dynojet were no help to me either. I also have a k&n filter. FMF Megamax II and a severly vented airbox lid.
Old Feb 9, 2000 | 11:01 AM
Harold's Avatar
Yes indeed, it sounds like you were VERY lean due to the vented air box!!!! Order some bigger jets or re-install the kit and cover part of your air filter with duct tape(richens the fuel mixture) if this helps your are too lean. Hope this helps.
Old Feb 9, 2000 | 11:03 AM
Harold's Avatar
Old Feb 9, 2000 | 02:09 PM
sparkys's Avatar
I guess I didnt clarify myself Harold . I tried to install the kit in my bike when it was totally stock . When I called Dynojet to ask them why the kit didnt come with a dynosheet like its supposed to , they said they didnt dyno a bike with the kit installed because they didnt have a K&N filter available at the time of testing .Kind of funny considering this jet kit came in a K&N atv power kit eh??? I then asked dynojet if the reason they didnt dyno a bike is because the bike wouldnt run long enough for them to dyno it!!! BAD MOVE . So much for any more tech help from Dynojet !!!
Old Feb 9, 2000 | 02:11 PM
sparkys's Avatar
Old Feb 9, 2000 | 02:12 PM
sparkys's Avatar
Old Feb 9, 2000 | 02:22 PM
sparkys's Avatar
