650 power outlet ?
Old Jan 15, 2002 | 09:12 PM
Scram500Man's Avatar
What is the Auxiliary power outlet on the rear of the quad for? Do you need to add the power outlet onto the circuit to be able to use it, or is it for some special Kawi accessories?
Old Jan 15, 2002 | 10:24 PM
Andrew84's Avatar
It's for any accessories, just like using your car lighter to power other things. I use mine for spot lights and a cell phone charger.
Old Jan 15, 2002 | 10:57 PM
Im talking about the power outlet on the rear of the quad, under the right rear fender. I'm not refering to the power outlet on the front of the machine. The outlet on the rear is inside of a rubber boot and you would need to unwrap it. The plug on it is a 2 prong plug one male and one female end.
Old Jan 15, 2002 | 11:17 PM
budweasel's Avatar
The plug is a standard 12v connector commonly found on 2 way radios & some other automotive type accessories. Like it says in the owner's manual, be sure to use an inline fuse for anything you attatch to it or there'll be no protection for the main fuse that protects the entire electrical system. The front lighter-type plug up front does have it's own fuse in the fuse block.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
salixair
Nov 3, 2015 08:25 AM
scorpiankill
Sep 10, 2015 09:14 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
byronman
Sep 6, 2015 06:34 PM
