Wider tires on Lakota Sport rubbing battery????
Old Jan 19, 2002 | 12:57 AM
QuadZmoto's Avatar
We put Dirt Devils 22x11x10, on Douglas.190 rims on the lakota, one problem they rub the battery! Anyone have any solutions? Thanks....
Old Jan 19, 2002 | 10:06 AM
stebob's Avatar
May want to look into wheel spacers, wider axle, or see if you can get off set wheels.
Old Jan 19, 2002 | 01:57 PM
Kawi250's Avatar
Try flipping the wheels around. I think they come ofset by about an inch. Try it and see what happens.
Old Jan 21, 2002 | 10:14 AM
98Lakota's Avatar
I had this problem when I put 20x11x10 Shredders on mine. I ended up ripping the battery box off during a race. I made a new box and mounted it under the seat. Works great.
Old Jan 21, 2002 | 11:14 PM
QuadZmoto's Avatar
Thanks for the replys. Switching the rims will not work, there is a 2" off set on the outside. I was able to move the battery box about 1/2 in inward, that helped. 98 Lakota, How did you relocate the battery under the seat? What did you use to make the new box? No problem when jumping?
Old Jan 22, 2002 | 09:57 AM
98Lakota's Avatar
I made the box out of some 1" angle. There is a section in the very back of the frame that is the perfect size for the stock battery. I had to cut some of the plastic under the seat to clear the top of the battery and I also made a new brace for the rear brake caliper that is about 1 1/2" longer than stock to move the caliper back some.
Reactant
Mar 30, 2022 02:08 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
John Boy
Jul 13, 2015 11:16 AM
Unzzy66
Jul 11, 2015 10:01 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
