bad a** looking atv
Old Jan 19, 2002 | 03:59 AM
100FTDBL's Avatar
ok i got a 91 250x and i need to know how to make the tires stick out more than stock... i need to know some parts you prefer to make it look good and run fast. i heard that you can reverse the tires and it will bring them out more but how much .... what i need is for you guys to help me find the best parts for the money thanx late....
Old Jan 19, 2002 | 11:29 AM
lonestarbanshee's Avatar
I dunno bout "reversing" the back tires, but you can flip your wheels around and make it a little wider.. I think. When you take your rear wheels off, look at the offset(if you're not familiar with that, its how much the center of the wheel is inset). You will want the wider part towards the outside of the quad. You can do your front ones the same way, with a little more work. To do your front ones, you will have to buy 4 new valve stems, and get out the drill.
Take the factory valve stem out, and replace it with a new one... Only thing is, put it so that the stem is INSIDE the wheel. Then drill a hole on the other side, and put a valve stem in regularly.
Good luck!
Old Jan 21, 2002 | 09:09 AM
Tcp11300ex's Avatar
Use durablue wheel spacers or durablue x-33 racing axle
