2002 raptor 686 woods racer (setup help)
Old Jan 28, 2002 | 11:25 AM
biggy's Avatar
As some of you know I was thinking about putting my motor into my woods racer ex . Ive dumped that idea and decided to build the raptor for this style racing. im needing help on setting this quad up to be the best it can be .here is my set up as to date .
1. 686 trinity motor mild cam 11:1 comp $1,100
2. wb r4 pipe $250
3. pro flow filter no cover $100
4. dyno jet kit $100
these are my thoughts for part's
1. + 1 1/2 swing arm $599
2. +1+1 a-arms (are these maid ?) $600
3. elka shocks ssd r&c $740
4 Rear shock ssd rebuild $400
5 anti vibe stem and new bars $250
6 dampner $150
7 alba paitiot graghics $139
8 razor tires $225
total for added part's $ 3,103
total for parts to date $ 4,653
Quad price otd $ 6,500
total wood's racer $11,153.00
Seem's to me this isint to bad of a price for a new rr quad ? does any one see anything that Im missing for a raptor rr quad I did forget it has nerfs and a kill switch already .
Old Jan 28, 2002 | 12:48 PM
95Warrior's Avatar
I don't see any skid plates to replace the stockers. I'd do the swing arm and engine minimum.
Old Jan 28, 2002 | 07:22 PM
Ward660R's Avatar
I don't know much about woods racing but I thaught at one time I heard some one say that a full +1 forward could make the ball joints bind. I'm not sure if this is correct so take it with a grain of salt.
Old Jan 29, 2002 | 01:56 PM
CBUS660R's Avatar
Timmy Boy makes +1" +1" A-arms. I have not seen anything about binding, but I have no direct experience to confirm nor deny. Don't forget reinforced or beadlocked rims.
Old Jan 30, 2002 | 11:39 AM
biggy's Avatar
I will look into timmyboy for the a-arms
from my exspearance bead lock rims are a waste of money stock rims with a rolled edege are very strong and I've never debeaded a tire yet .I run razor tires and they seem to have a good bead on them . took 60 psi to bead them on my ex ....man I was shaken ??? tick tick boom ......
Old Jan 30, 2002 | 12:31 PM
CBUS660R's Avatar
I must be unlucky. The first hard ride with my new 6 ply 23" Razrs on the front, I overcooked a corner (didn't adjust my riding style enough for the 3" of wet snow), clipped a tree and popped the left front clean off the outside bead and pushed the tire all the way over to the inside. Also tweaked the rim so it has about 1/4" runout now. This was with 6 psi of air on stock rims. I didn't bend anything else, so all it did was ruin a ride.
bmxatv10
Oct 14, 2022 06:23 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
