Motor question
Old Jan 30, 2002 | 07:00 PM
Shift's Avatar
a few weeks ago, I drowned out my recon in a water hole... more like a pond I guess but thats another story. Anyways, right after I did it I changed the oil, and I've got it looking the color oil should now after changed it 5 times. my other problem is this... It starts, but it misses. The weird thing is, if you ride it at idle or 1/4 throttle it misses, but if you gas it real fast and put the motor under a load it runs fine, but once it gets up to speed and gets the load off the motor, it starts running horrible again... whats the problem?
Old Jan 30, 2002 | 08:31 PM
ChevyGuy's Avatar
Did you ever clean your Carburetor? If not clean it and that should make it run better.
Old Jan 30, 2002 | 09:35 PM
Shift's Avatar
I didnt "clean" it, but I did get a bit of muddy water outta the float bowl and overflow tubes. I'll take it apart tommorow and check it out.
Old Jan 31, 2002 | 02:13 PM
biggy's Avatar
also make sure your air cleaner is clean and DRY!! replace the spark plug take apart all electrical connections and blow them out with compresed air the reinstall them with dielectric grease ...might help
Kyle5050
Dec 13, 2019 04:25 AM
ronnierhino06
Nov 9, 2015 12:56 PM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
