Top It Off
Old Feb 2, 2002 | 02:39 PM
CaTTrax's Avatar
When your new wheeler comes from the factory the antifreeze is full but after you ride for awhile the air pockets in the cooling system will purge the air and you will now be low on antifreeze. when you do your first oil change DON'T forget to check & top off the antifreeze.
P.S. Don't just put strait antifreeze in it, mix it 50/50 with water or use ARCTIC CAT antifreeze it is already mixed 50/50.
