Web Cam for a Wolverine (Help)
Old Feb 14, 2000 | 10:12 PM
boomer's Avatar
I am in the middle of installing a Web Cam and Wiseco forged 10.25:1 piston. When I took the old cam out, I noticed that the front bearing was pressed on, and the sprocket pin was also pressed into the cam. The new Web cam came with neither of these. How do I get the pin and bearing out of the stock cam, or should I just get a new bearing pressed onto the new cam. Please help. I think the pin is reusable if I can get it out.
Old Feb 14, 2000 | 11:51 PM
Tree Farmer's Avatar
I'd take the new and old cam to a shop where they A) Have a hydraulic of arbor press, and B) know what they're doing, asking the shop to fit the pin, sprocket, and bearing onto the new cam, assuming all old components are in good shape.
The ol' sledge & punch routine appears too risky, if you can get access to the proper tools and techniques.
Tree Farmer
Old Feb 15, 2000 | 01:27 AM
thumper4x4's Avatar
Hey there Boomer, sorry been a little busy
I would suggest replacing the bearing. You can easily press the new one on your cam, find a suitible driver that only touches the inner race of the bearing, then fold a shop towel over a few times and place it on a sturdy work bench.
Put the the cam on end on the towel and tightly tap the bearing on the cam till its just started.
Then drive it on with the driver, just be real careful not to hit the bearings.
I believe they cover this repair in the shop manual <- good idea....
As for the pin, if you can get it out without damaging it, its ok to reuse.
Hope this helps
click the link below...
Old Feb 18, 2000 | 04:56 PM
Harold's Avatar
Hi Boomer, keep us informed about your performance results, I'am thinking about doing the samething to mine!!
Old Feb 19, 2000 | 08:37 PM
boomer's Avatar
Will do. I have everything in except the head, which Thumper 4X4 will be getting in about 2 days. It was pretty easy. I also put on new handlebars, sealed front wheel bearings, Baja swingarm guard, Wiseco forged piston .20 over, valve spring kit,port and polish head<- (couple of days)
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
