wolverine help
Old Feb 18, 2000 | 08:29 PM
wolverine_4x4's Avatar
what kind of oil would u reccomend me to put in my 95 wolverine
Old Feb 18, 2000 | 09:24 PM
jed's Avatar
jed
wolv i've a 00 and i use 20w50 kawasaki motor oil recommended by my dealer.
Old Feb 18, 2000 | 10:57 PM
thumper4x4's Avatar
Well a little info about your riding conditions, and what you`ve done to the bike would help giving you accurate advise.
However I have a highly modded Wolverine I race and trail ride In California. I also have an oversize oil cooler and manual clutch.
I run Mobil 1, or Casteroil Syntec 5w-50 synthetic.
Hope this helps...
click link below
Old Feb 19, 2000 | 02:27 AM
Stroke9's Avatar
How did you install a manual clutch and where did you get the parts. Do you still have reverse. I am interested in the Wolverine and that mod with a twist grip would make it an ideal machine.
Old Feb 19, 2000 | 11:08 AM
my wolvierine i s all stock its a 95 and the temkperature around here is between 75-90 so what kind of oil should i use i just put 10w-40 in it but i read something about oil and didnt know if i was using the right kind?So i would like to knonw what kind of oil to use?
thanx
Old Feb 19, 2000 | 05:28 PM
musclford's Avatar
I use Valvoline Durablend.
According to the specs, its one of the best for the climate I ride.
Old Feb 19, 2000 | 10:15 PM
thumper4x4's Avatar
Well Wolverine 4X4, with those temps, the oils I listed as my preference would be great. I would think about an aftermarket oil cooler though
As for my manual clutch mod. It is from FST, however it is not easy to get right. The setup and adjustments took me a while to get right. I had to modify it a little, but it rips now. And takes 5lbs. off the crank.
suzuki230
Jul 8, 2016 10:03 AM
Nelson
Jun 22, 2015 03:51 AM
Nelson
Jun 20, 2015 01:59 PM
ragewraps
May 27, 2015 08:07 AM
holmbergm97
May 27, 2015 07:23 AM
