Is this 400ex good
Yo i just wanted to know does a 400ex have more power than a warrior... Plus how much does a warrior way and how much does a 400ex weigh.. and could u tell me how much a warrior is then how much a 400ex is thanks.....
My opinion a 400ex has more power and is faster. It weighs 375. I dunno wut the warrior weighs but u can fine out the specs from these too websites. www.hondamotorcycles.com
www.yamahamotors.com
2002 400ex listed $5699
its really hard.The warrior weighs 397.The 400ex weighs 375. the warrior's price $4999.The 400ex's price $5699. Warrior has 6 gears and reverse. 400ex 5 gears no reverse. Dude its all up too u.
www.yamaha-motor.com
If your talking 400ex and you end up getting a warrior I am afraid after a short learning curve you will wish for the 400ex. I am not sure how you can compare these machines because there so different. The only the thing warrior has over the 400EX is reverse. Both machines will get you from point A to point B, but you will have a more pleasant ride on the 400EX. The design of the 400EX is at least 11 to 12 years newer.
Chet
Chet
I thought a Warrior wieghed 420 pounds dry? Anyway I think the 400ex will out perform it in every way. Reverse is over rated 90% of the time you end up using it for convenience not necessity. After having to turn it around by hand a couple of times you'll becom instinctive about not getting into situations that require it. IMHO
Yes, some frogs are water tight. They form a hole, get in it, then put mucus all over there outer most self's and can just wait out all bad situations because they sealed in there own zip-lock container.
Nows that'something what nature can do for them frogs and what Honda did for the now famous 400ex.
Chet
Chet
