Valve Shims
Old Mar 1, 2002 | 09:08 PM
ScoobyDFW's Avatar
What size valve shims are people running after mods such as cams, valve springs, etc? For some reason I am at the smallest Bombardier shim size and still need more clearance. BMW sells slightly smaller shims, has anyone else had to go with non-Bombardier shims smaller than 2.10mm?
http://faq.f650.com/FAQs/Valve_Shim_Change_FAQ.htm
Old Mar 2, 2002 | 12:33 AM
glamisds650's Avatar
after replacing my cams and springs, i went the opposite way running 2.75 and 2.80 now
Old Mar 2, 2002 | 12:34 AM
PaRoostR's Avatar
Have you checked if you stretched your necks?
Old Mar 2, 2002 | 02:28 AM
Knutz's Avatar
Three possible causes-
1- valve job that sunk the valves deeper into the head without ginding the ends the appropriate amount to compensate. This is caused by someone doing head work that didn't know how to do it right. The head should be checked to ensure that too much valve or seat material hasn't been removed. If too much valve material is taken, you could end up with-
2- "Tuliping" valves, the valve face is actually cupping, allowing the stem to travel too far into the head. The only proper way to fix it is to replace the valves. Once they start to "tulip" they continue untill they break.
3- The last option would be a cam ground on too large of a base circle. If the base is too large, there would be no room. The valve stems could be ground to compersate, but care must be taken to ensure proper clearance remains after the grind.
I've done ALOT of shimming, and never had to go that thin befor.
Old Mar 6, 2002 | 08:48 PM
Batoutahell's Avatar
Scooby, You may have already figured this out, but I was told that the shims for the kawasaki klr650 are the same size shim that our engines use. I was told this by glamisds650, so maybe he can tell you more.
I found a place that has them down to 2.00mm.
here
If that helps you out.
Bat
Old Mar 6, 2002 | 10:38 PM
here is the site that sells the shims for the klr650, they are 29mm shims and they have sizes down to 2.00. shims
Old Mar 6, 2002 | 11:35 PM
glamis, have you actually ran these? Or do you know of anyone that has?
I don't have a local bomb or bmw dealer, but I do have a kawasaki dealer, so I might try using these shims.
Thanks for any info
Bat
Old Mar 6, 2002 | 11:45 PM
yes, i bought only one from the kawasaki dealer($10.00). i was in a bind and they are the only ones here that had it in stock. now, i buy or order from BMW. they have the best prices i have found.
Old Mar 6, 2002 | 11:50 PM
bat, if you are going to do the install of the cams, piston, etc.. yourself. you had better have alot of different shim sizes available. also don't forget the compression washer for the cam tensioner bolt.
good luck!!!
Old Mar 7, 2002 | 12:01 AM
Glamis, I was thinking about having plenty of the shims available, or getting everything installed and taking some measurements and then ordering the shims I need. Thanks for the info.
I guess I need a compression washer. I will see if knutz has them and can send me one. Thanks for the heads up.
I ordered a service manual, but I don't have it yet, so I may wait to do the install until it comes in.
Thanks
Bat
