Anyone wire their 450 ES to Start in gear ?
Old Feb 22, 2000 | 11:56 AM
djlewis's Avatar
I would like to wire my 450 es to start in any gear. If you have done this or know how, please post instructions.
Old Feb 22, 2000 | 12:03 PM
FOREMANes's Avatar
Do a search under Gordon Banks, or look back like 60 days or so in the honda forum, That was covered along with the center head light bypass switch....(for when YOU got a bunch of stuff on your front rack..it won't blind you) I haven't done it to mine yet but I think I will soon...
Hope this helps
Old Feb 22, 2000 | 10:21 PM
Keith Rose's Avatar
DJ, here is the text from a 6/11/99 post written by Mark Sibbers. Hope this helps.
"I rewired my Foreman 450ES to start in any gear. Tap into the green w/ red tracer wire and connect that wire to a grounded switch."
Good luck!
Keith
Old Feb 22, 2000 | 10:44 PM
JRM's Avatar
JRM
my 200SX broke someting inside the case and now it starts in any gear..but the N light stays on glowing bright green while rideing..kinda bugs the heck out of me.
Old Feb 23, 2000 | 10:36 AM
Stump's Avatar
The directions Gordon gave will have the same affect the Neutral light will be on all the time.
He has his wired to work normally BUT he said it was a tough job and to much to give in email.
Old Feb 25, 2000 | 07:59 AM
sibbs's Avatar
I did this to mine and it wasn't too difficult. There is a starter solenoid beneath the seat next to the battery. I tapped into the green wire with the red tracer and ran that wire to a doorbell switch that I have on my upper left front fender. I drilled a hole in the plastic to install the doorbell switch. Then all I did was ground the switch.
The doorbell switch I bought at FleetFarm, it's a switch where I could screw on plastic switch cover to keep the mud and water out of the switch.
When you close the circuit on the switch your neutral light will come on even though you may be in gear. While holding in the doorbell button you can then start your machine. As soon as you get it started and let off the doorbell button your neutral light should come off.
After it's started I'd shift it down to first gear because the computer doesn't always recover what gear you started in.
good luck,
mark
tiresharkdbb
Sep 3, 2017 02:06 AM
txkevin
Sep 21, 2015 02:02 PM
FWhitt
Jun 13, 2015 02:22 PM
clsharky
Jun 8, 2015 11:38 AM
1000gade
May 27, 2015 12:37 PM
