Baja electrical problem
Old Mar 17, 2002 | 07:33 PM
Bombrunner's Avatar
A buddy of mine has a '01 Baja. He has blown two 25 amp fuses that power the starter. We found that when he turns on his lights the fuse blows. Is there a quick solution to his problem?
Old Mar 17, 2002 | 11:14 PM
ScoobyDFW's Avatar
I've seen a loose/broken taillight wire shortout to the metal housing causing blown fuses.
Old Mar 18, 2002 | 04:22 PM
Hightower's Avatar
Its not just a fuse for the starter - its the main fuse for everything.
If turning on the headlights is what is blowing the fuse, then it must be one of the following:
1) Damaged wire between healight and switch housing on bars, shorting to ground.
2) Damged bulb enclosure, somehow shorting.
3) Damaged wire between switch enclosure and tailight, shorting to ground.
4) Damaged switch enclosure.
Old Mar 18, 2002 | 07:27 PM
glamisds650's Avatar
check that the headlamp and / or any other cables are not rubbing against the steering stem and shorting out- mine did.
skinnyr6
Aug 25, 2023 02:18 AM
chammerbeck
Jul 17, 2015 08:06 AM
Unzzy66
Jul 11, 2015 10:01 PM
Chocobamofo
Jul 10, 2015 07:46 PM
ranvette
Jul 4, 2015 06:13 PM
