BANSHEE ENGINE MODS.
Old Feb 23, 2000 | 12:32 PM
clemi's Avatar
WHAT IS THE BEST AND EASIEST COOLHEAD TO PUT ON MY BANSHEE. AND IS IT REALLY SIMPLE TO DO. AND LAST BUT NOT LEAST AROUND HOW MUCH DOES IT COST?
Old Feb 25, 2000 | 12:44 PM
madrowler's Avatar
I bought the pro design cool head with the 20cc domes for more compression. I put it on myself in about two hours. The engine runs much cooler and i notice that i don't overheat anymore. It will cost you around 280-300 bucks.
Old Feb 26, 2000 | 11:40 AM
Dune_Scooter's Avatar
Pro design makes a great product, but I would imagine all aluminum heads work well. ADA says their head doesnt need longer studs like the pro design does. The studs do come out easily though. I run a pro design and noticed a big difference. Be careful on what size domes you use. If your crank hasn't been welded, you dont want to go with to small of domes. It will increase the risk of your crank spinning out of time. Your altitude and year of bike will make a difference in how small of domes you can use. you will also need to pick up some larger main jets too. As you increase compression, you need to supply more fuel. As a general rule of thumb, they say you should run race fuel, or partial mix with race fuel and gasoline if you exceed 150 lbs of compression. Again, your altitude will determine this. I run 21 cc domes and run at 140 lbs compression in mine.
They do work well and I would recommend one. Good luck.
Old Feb 27, 2000 | 03:37 PM
yfz380's Avatar
some people say that milling your stockhead is the same and alot more cost efective i had mine done .80 removed and rechamber so the piston doesnt hit thehead ive had nothing but fun since for about $90 vs $250-$300 for coolhead
and it hasnt overheated not once
Cole Hadden
Jun 15, 2025 09:05 AM
JohnnySplat
Aug 6, 2015 12:07 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
cSchwartz
Jul 9, 2015 02:40 PM
Jul 7, 2015 11:00 PM
