Painting Mojave Cases!
I own a 1999 Mojave. It is white with a red frame. I got the idea of painting the cases from Kawi250's post about polishing them. I think it might look kinda cool with some red down there in the engine. It would look cool on the green Mojaves and the Lakota Sports too. I just wanted to know what you guys think about painting them, and what kind of paint I should use, like high temp paint for an engine block or something like that.
I still don't know if I will do this or not, but if I do I will paint up all of the covers like the clutch and water pump cover, and I will post pics if it happens.
Let me know what you think.
it would be awsome until the paint started to wear off where your boots rub
i have a 97 with a red seat and hood so it looks just like a 99 i like to put red paint where it says kawasaki on like the clutch cover and stuff also on the cylinder where it says doch 4 valve
Mojaveman1:
Do you know if there is any type of clear coat that I could put over it without the heat messing with it. I can paint them red then put some clear coat over them, and that should help to keep the paint on longer.
Later
Later
but the clear coat would probably scratch and make it look bad
i have seen banshees that have had colored cases it looks like a professional job tho
try to find a company that does alot of crome like crome a arms and i bet they will get ya somthin
