A few ??s About trailblazer.
I have a 99 TB and I was wondering what the compression reading should be? The last time I checked it I had just about 100 psi. Is that good or do I need to rebuild it? One more ? can just put rings in it or do you have to put a new piston in it also? Bye the way it is still stock.
I do not know what the compression ratio is but I do know that I have changed rings serveral times without replacing the piston or without reboaring the cylinder walls. A lot of times the rings wear and as long as you rough up the side walls of the cylinder walls with some very fine emery cloth or hone it out with a rotory honning tool like on your drill. Then put her back together and run easy for an hour or two to let the rings seat and your ready to go.
good luck
good luck
The book says the service limit is 115 psi. So if yours
is at 100 psi I would say its close to needing some work.
My service manual does not say what the compression should
read. Only that its (std.-+ 15%) Whats the standard?
Hey thanks for the answers to my ?s. Do you know how much a ring set is for a stock TB and do you have to use stock rings or can I use wiesco rings or something else? By the way what is the torgue settings for the head bolts ?
