Kill Switch
Old Apr 17, 2002 | 11:47 PM
98Lakota's Avatar
Who has a Pro Design kill switch on their Lakota and what wires do you splice into? I have heard of people blowing fuses by connecting to the coil.........so which wires do I use?
Thanks for any help...
Old Apr 18, 2002 | 01:25 PM
98Lakota's Avatar
OK...How about on any quad with a battery?
Old Apr 18, 2002 | 04:42 PM
mojaveman1's Avatar
im also lookin into the same thing on the mojave
if anyone one on here races which it seems that everyone claims to it is a rule at almost any track to have a kill switch
Old Apr 18, 2002 | 06:51 PM
NTHEWND's Avatar
Hay 98 sorry for the delay: I checked out the way mine is wired. The wire from the main body of the kill switch is spliced into the green wire with a white stripe. The wire from the part that will slide into the main body is grounded to the frame. Let me know if it works for you. Dave
Old Apr 18, 2002 | 06:52 PM
AlkyBurninX's Avatar
When you buy the switch the instructions tell you how to wire it to an ATV with and without a battery. So you know, with a battery you will install the short wire to ground. The long wire will go to the pulse trigger wire on the stator. You really need a wiring diagram to find out which on this is. The only other way is to remove the stator cover and see which wire is coming from a little black box.
Without a battery, the long wire is hooked to the wire going into the coil.
Hope this helps
Old Apr 18, 2002 | 11:36 PM
98Lakota's Avatar
I would have read the instructions, but I got this switch in trade for some welding on another machine.
Thanks NTHEWND, worked like a charm....see you at Loretta's
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Halffast17
Sep 11, 2015 02:30 PM
alzgarvin
Sep 11, 2015 08:53 AM
Albertaboyy
Sep 9, 2015 09:51 AM
toonces
Sep 5, 2015 01:14 PM
