Tricks
Old Feb 29, 2000 | 11:38 PM
200s's Avatar
Hey, i've got an '85 ATC200s and i'm only 16 and i'm wanting to know what i could learn from you exprienced tricksters out there. Is there anything out there i could prosibably learn to do that wouldn't require to much height or risk of breaking something. The 200s's wheren't real big on the suspension factors. Only a front mono shock. And wheelies are no problem i can hold them for +-20 feet, in second gear.
Any tips on what i can try without killing myself? Thanks
200s
Old Mar 1, 2000 | 03:21 PM
RDex's Avatar
i had an 84 200s a couple years ago
it was awsome. not sure what kinda tricks
your talking about. if your into muddin' put
some maxxis sur tracks on the back, they were
unbelievable in the mud. or if you want it
to slide good around corners get a rear tire with
a more square profile like a hole shot or the 22inch bandit. it will corner better too with
the stiffer sidewall,its alot more stable too
at higher speeds with a sport tire.
Old Mar 1, 2000 | 10:50 PM
Ryda's Avatar
I HAD a 200S till someone stole it out the back of my Dad's ford.Anyway,I loved it.I had trail-pros on the rear and H-trak on the front.Tricks?Try riding on some gravel area and get it wound up 'bout third(or second,depending on what speed you like)swing the rear end around and hit that throttle and turn,360 degree turns all the way till you wanna stop,pretty fun.Also,get on an open area,stand up,grab the front brake and give it gas,and let off the front brake,straight up wheelie,thats fun.2nd gear wheelie???I took the airbox lid off of mine and I could give it gas and make it wheelie all the way into 4th.That thing could slide like nobody's buisness.
Old Mar 1, 2000 | 11:35 PM
200s's Avatar
Thanks guys for the tips, by tricks i ment just simple little things i could do to show off with. I never thought about taking the air filter cap off. That makes sence though. =) And sorry to hear you got that 200s of yours stolen a while back, i had mine taken out for a "suspected" joy ride and over turned in my ditch. Bent and broke a bunch of stuff.
200s
snake99
Sep 30, 2015 07:31 PM
mattcraig1
12
Aug 27, 2015 12:23 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
350Trixter
Sport Quads
23
Jan 29, 2000 12:34 AM
