Need help on an old Honda
The '86 wasn't available in the Foreman version. Here is the break down.
1986-1987 TRX350 Fourtrax 4X4
1987-1989 TRX350D Fourtrax Foreman 4X4
The 350 models did not have front or rear racks, the large front bumber, and had narrow mudflaps.
The 350D models[Foreman] had front and rear racks, large bumper, and had wider mudflaps. These also had the removable headlight on the handlebars that could be used by hand as a spotlight.
The tenth digit of the serial number will verify the year model.
G-1986/H-1987/J-1988/K-1989
Your Honda dealer is the only place that you get a manual which has breakdowns on parts with part numbers. They run about 25.00
There are also a few places on the internet which have parts fiche available to view. Maybe some other forum members can help you there.
To add to the information, Foreman 350D has 2 lights in the front bumper that are clear like the headlight. The 350 has 2 lights that are amber in the front bumper. Stand in front of the machine and look at the lower frame crossmember, should be a decal with the year and on the left lower corner of the decal 350D if it is a Foreman, will be just 350. The vin # will be stamped just above the decal. Also on the right side of the decal it will give the month & year of build i.e. 6/86 will be called a '87. I think Honda is the only source for a parts book.
Hope this helps.
Pullerguy Les
Hope this helps.
Pullerguy Les
Pullerguy~
I do a little repair on the side and a guy brought me the 86 with a front 4x4 hubs messed up. The housing had holes in it from bolt breaking loose inside. Not a good thing, it's going to be about $350 to fix.
