what is the coolant filter of carburetor on the 650 ?
Old Apr 28, 2002 | 10:49 AM
TrailHog's Avatar
Hope this doesn't sound stupid, but are the carbs water cooled on the 650, if not what in the world is that coolant filter doing hooked to the carbs ( it looks like it's hooked to carbs anyway, maybe not ). I don't have a manual yet so I'm confused.
Old Apr 28, 2002 | 11:06 PM
nyroc's Avatar
It is not a filter, it is a flow restrictor. There is a little white piece of plastic inside it that reduces coolant flow. I know this because mine melted and let all the coolant out. I just plugged the hoses and kept going. But I will fix it soon. I'm not sure how it happened, the water was not too hot, but that plastic thing melted and ruined my trail ride. I think I will use a brass fitting there so it won't melt in the future.
You are right, the carbs are cooled to eliminate vapor locking.
Old Apr 29, 2002 | 07:50 AM
trx450's Avatar
NYROC--- How the hell did you melt the carb coolant filter/restrictor?????
Old Apr 29, 2002 | 08:11 AM
nyroc's Avatar
My radiator was pretty much clogged, and my tire was flat. That caused the engine to get pretty hot. The overheat light never lit, and the water did not boil over.
That little plastic thingy melted at way too low of a temp. I will post a picture of what I am going to replace it with.
Old Apr 29, 2002 | 12:54 PM
nyroc's Avatar
I don't know if anybody cares about this, but here is what I did to fix it.
http://atv.dnsalias.com/atv/prairie6...ir=&pic=24
I wanted to replace it with something else other than easy melt.
Old Apr 29, 2002 | 01:41 PM
trx450's Avatar
NYROC-- thanx for the update. It is something that could ruin your day, if it broke/melted 40 mi from your truck! I am always interested in lille details such as this!
Old Apr 29, 2002 | 03:10 PM
PrairieDust's Avatar
Trailhog, to answer your question it's actually designed to keep you carbs warm so that they dont ice up in the winter. I was really glad to see these in stock form because I had to add a heater to my older prairie 400 to keep it from icing up and not wanting to idle.
Old Apr 29, 2002 | 10:15 PM
TrailHog's Avatar
Thanks for the info everyone, Nyroc , I'm glad you posted that about the coolant plastic thing melting, I will keep a eye on it, never thought about it melting before.
Old Apr 29, 2002 | 10:27 PM
nyroc's Avatar
I wonder if it was weak because I got gas all over it when I changed the jets?
I still can't figure it out. The water was not boiling over before, couldn't be that hot. The crankcase wasn't that hot.
Why did that cranky little thing burst open?
Oh well, matters less to me now than everyone else. Mine is brass now.
Old Apr 30, 2002 | 04:23 PM
northarkie650MUDD's Avatar
why didnt you drain fuel bowls before changing jets?
