A-Arm for 300ex
Old Mar 1, 2000 | 10:54 PM
300exx's Avatar
Does any body know where I can get an A-Arm for a 300ex?
Old Mar 2, 2000 | 12:37 AM
hakmazter's Avatar
If you get replacement size 400ex A Arms, they will fit and be equivalent to +2 300ex A Arms. If you get +2 400ex then they will be +4 on the 300ex since it has a wider frame. 400ex A arms are a dime a dozen and they fit the 300.
Old Mar 2, 2000 | 10:32 AM
Brad_L's Avatar
Yes, the 400ex a-arms will fit, but please remember that the top shock mount will have to be modified. Because in stock form the 250x shock will be too short and the 400ex shock will be too long. Atv Racing sells a bracket that will correct the top shock mount to run the longer shocks. Also keep in mind that you will also need the tie rods and brake lines from a 400ex also to make the conversion run smoothly.
I have a 91 250x with 250r a-arms on it and I love it.
Old Jun 25, 2000 | 06:09 PM
hondatrx300ex's Avatar
I was thinking about doing this. I figured I could find some used +2" 250r a-arms,get the shock mount,then maybe buy me some works 250r shocks. I kinda want the +2" 250r a-arms since wider is better. I'm sure I'll do this sometime down the road but not anytime soon.later
Old Jun 26, 2000 | 12:39 AM
veedell's Avatar
I have 400EX A-arms and shocks on my 350XX (300EX frame, 350X motor) and this is the cheapest and one of the best setups you can do for your 300EX. You can buy new 400EX shocks for about $150 each, A-arms are about $120 per side, and tie rods are cheap, about $5. (keep spares, the longer tie rods bend easy) Your same brake lines work with the longer A-arms too, so you don't need to buy new ones. I have made my own bracket for the shock mount and it bolts up to the stock location so there's no welding on the frame, and if you ever want to put it back to stock to sell all you have to do is unbolt the bracket. I have run both the 400 and 250 shocks and the 400's are much better. If you want anymore info just email me.
nosaj
96 350XX
#94 MHSC
#401 SOIL
Old Jul 2, 2000 | 11:19 PM
hey I'm fixing to buy some 89 250r a-arms on ebay. so how hard was it to make the new bracket?how far up and out did you have to go?? I plan on using the 400ex shocks with the 250r a-arms....only problem is the shock mount....the one from Atv racing is $140. I wonder how far it goes up? cause there is a fender brace right above where it is supposed to weld. anyways I'm sure it isn't a problem. I guess I'll go with 250r a-arms 400ex shocks and ATV racing weld in kit. ok later,Jake
Old Jul 3, 2000 | 12:03 AM
veedell's Avatar
It took me about $7 worth of steel from Lowe's and about a half hour to make my bracket. You only need 1/8"steel and a small 70 amp welder to do the job. I am working on puting some pics on a website sometime soon too if you wanna check it out.
nosaj
96 350XX
#94 MHSC
#401 SOIL
Old Jul 3, 2000 | 08:39 AM
$7 or $140? gosh I wish I could just build one like you did. it would nice if you had some pictures and maybe I could build it. so it just bolts to the frame?that would be good so I don't have to weld on the frame. is it plenty strong? anyways see ya
Old Jul 3, 2000 | 08:50 AM
94DGblaster's Avatar
Will a set of 400EX A-arms and a set of 400EX shocks fit on the 300EX with no mods?
Old Jul 3, 2000 | 06:43 PM
Brad_L's Avatar
Hey you guys,
I have information on this conversion on my site including stock measurements as a guide. Please look.
Link below,
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
ScopeZ_
Sep 13, 2015 07:55 AM
Wiley wolf
Sep 7, 2015 08:32 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
XxS0ccerstarxX
Aug 31, 2015 04:47 AM
