mojave carb ?
Old May 2, 2002 | 10:33 PM
leeh's Avatar
I want to replace my stock card what do you all recomend?I thought about a keihin pwk35 carb but dont know were to start with the jetting. thanks
Old May 3, 2002 | 10:54 AM
mojaveaddict's Avatar
That is typically considered to be a 2 stroke carb. The stock carb is hard to beat. A carb alone will not help perf much and in most cases will actually hurt perf. A carb should be the last mod chosen and should match all the other mods. I have tried the 38 mm carbs and find them a little too large for the mo to make good bottom end. A 36 mm carb like the mikuni flat slide 4 stroke carbs are a good choice for a modded motor. If you only mod with a pipe and better filter then the stock carb with the right jetting is usually going to give the best performance.
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Mojave250A
Ask the Editor
Jul 12, 2015 09:10 PM
Mojave250A
Jul 11, 2015 10:38 AM
