mojaves weight loss
Old May 8, 2002 | 12:29 PM
mojavekid13's Avatar
I just wanted to know so things i couls do to make my mojave loose so weight!I know I wont be able to tak off lots but i wouls likw to take off 10-20 pounds.Any sugestions would be helpful
Old May 8, 2002 | 02:06 PM
mordr's Avatar
It looks like you have already shaved off a lot of weight-have you taken off the factory nerfs? I had to with my DG's, but I don't know about AC's-those factory things are pretty heavy.
I took off the parking brake cable, brake light and wires to it and with the hood went the headlight and all wires.
Some people on here have taken their antifreeze overflow tanks off. I took off the large bracket that holds it (and also is attached to the mud flaps) and moved the mount from the left side of the engine to the right-you may have to go look at it to understand what I am talking about-probably not explained too well.
This tucked the bottle inside a little more. I used a zip tie thru a hole I drilled in the black plastic holder to hold the bottom.
You can also get a new clutch lever that would elimate the p-brake stuff on the handle bar.
If you feel like tearing your whole bike down you can cut off any useless tabs and get the frame powder coated again-I saw where Lurch has done this on his site. Hope this helped a little.
Old May 8, 2002 | 02:12 PM
ya thanks alot i havent took off my mud flaps yet so thats why i still have the bracket! iam not sure if i should take them off or not because i do alot of mud riding! have any of u had any problems with them off?? i would love to hear some of your input
Old May 8, 2002 | 04:43 PM
mojaveman1's Avatar
replacing the handle bars with aluminum
Stock ones are steel
rear skid replace with aluminum and full chassis aluminum
stock are steel
grab bar is steel
replace with ac aluminum
looks like you got rid of that heavy air box
take off stock nerfs
Dammar
Apr 20, 2016 06:03 AM
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Sw00p
Sep 24, 2015 02:50 PM
alzgarvin
Sep 11, 2015 08:53 AM
