Need help with aftermarket goodies for a 400EX.
[img]i/expressions/face-icon-small-confused.gif[/img]
I need help with mainly the tires, shocks, and pipe to get. So far, I plan on getting 6-ply razrs, Works quadstar rear w/ rezzy, and works triple rate fronts, w/ rezzy, then, I plan to get the FMF titanium-4, stainless connector, and powerbomb head pipe. Thanks.
I put Works triple rate, non rezzys on the front of my 400, and was amazed at the difference. I mainly just trail ride, and the other aftermarket shocks were too expensive for what I use the quad for.
I also put a Yoshimura slip on on it. I didn't want anything too loud. Again, I was very pleased with it's performance over stock. I am running a K&N with a 165 mj.
I just finished installing Houser +1, +1/2 a-arms, and stainless steel brake lines, but haven't test ridden it yet, I can't wait to, though.
I also have a Lonestar Axcaliber axle, and a Houser +1 1/4 swingarm on the way.
I will be adding a 416 kit this fall.
If your going to spend money on shocks , your better off taking your money and putting it into a decent set , Elka makes awesome shocks from what i hear and they aren't TOO much more than works.
[img]i/expressions/face-icon-small-happy.gif[/img] Thanks Guys! I'm sorry about not telling you what type of terrain I ride, I ride desert. I saw a drag race at horn rapids, in eastern wa., and all the guys told me to get a powercore 4, and the same header. Thanks for all your help, and you probably don't want to hear the rest of my huge list of stuff.
[img]i/expressions/face-icon-small-cool.gif[/img]
Hey, Quadfather, where'd you get you a-arms, axle, and swingarm from, after I'm done with all the other 3,000 dollars worth of parts, I'm gonna get a-arms, an axle and swingarm, all Lonestar, and an axle carrier, and anti-fade lock nut. If you want to help me out a little more, then here's the rest of the stuff I'm getting: Fmf power core 4 and powerbomb head, as you know. K&N jet kit, Maier atv handguards, Ricochet engine, and swingarm skids, (razrs) Dura blue wheel spacers( before a-arms), DG alloy nerfs, K&N air filter, DG alloy bumper, and a Denton steering dampener. Also, what size of jets should I run? I might get steel braided brake lines, Pro taper bars w/ pad, MSR cluth and brake lever set, magura hydrolic clutch, and Hinson clutch basket. I ride desert, weigh 117 lbs, very aggressive, and competitive. Thanks.
P.S. I might clip the front fenders.
Dont put the fmf power core. They suck and they're loud as hell. if you dont care how loud it is go with a curtis sparks. They're freakin' sick. I also dont recommend the razrs. first their flat on the bottom which, unless you thouroughly enjoy sliding all over the place, are not going to hook up worth a crap in the desert. I had the bandits and my friends viper blaoon tires on his identical 400 beat me by a full length and a half. secondly, they wont last. with the gooopy trad they got on em your lookin at about six rides. you do realize they were designed for MX. just some words from experience. :/
