KLR Black Box on Mojave
You can find a KLR box at your Kawi dealer or check around online for a dirtbike salvage yard. I have bought parts from a place called Cycle Salvage in CT. Their phone is 203-993-1600. They deal in street bike only, but since the KLR is a dual sport, they might have a box. Used is usually half of new. Although I am not famialar with the wiring on the Mojave/KLR, I had to swap a couple of wires when I put a 300ex box on my 250x. You might have to do the same if the mojave has a reverse rev limiter (since the KLR doesn't have reverse). You might be better off to call someone like Sparks Racing. They have high-rev boxes for many different models.
It's much cheaper to just send your mo box to Mickey at FST and for 80 dollars you get the rev limiter removed. I think the timing on the klr box is a little more aggressive but not enough to make a real difference and may cause detenation on a mo using pump gas.
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
