650P display not working!
Old May 14, 2002 | 04:38 PM
northarkie650MUDD's Avatar
anyone know why my display wouldnt be working? the LCD portion doesnt work, but the little LED's (reverse light, nuetral light, etc.).
Old May 14, 2002 | 10:43 PM
kingmort's Avatar
Pretty hard to say without being there to look at it.I would check easy stuff first.Start with checking the fuses(they're under the seat)Then pull the handlebar cover off and make sure all the connections are plugged in properly.(there are 4 screws that hold that plastic piece on)
That's all the help I can give you.
Old May 15, 2002 | 12:46 AM
thx, tried that already.
Old May 15, 2002 | 11:23 AM
kingmort's Avatar
Figured you probably had already, guess its time for a wiring diagram and a test light..
Old May 16, 2002 | 06:59 AM
scootdog's Avatar
probably heard this already, but check all connections..
Old May 21, 2002 | 11:53 PM
kawlaris's Avatar
Alot of LCD displays will have a ribbon cable internally. This ribbon cable will slide into a connector of some kind that is attached to the lcd display. This maybe dirty or has come out of the connection. I have not had mine apart to see actually how it is built but you may want to check it. It could be something quite simple.
Old May 22, 2002 | 01:40 AM
thanks, ill try that.
Old May 22, 2002 | 08:13 PM
Roofer's Avatar
Doesn't care what people ride as long as they can keep up!
I had this problem. It is hard to see, but it is probably a loose connector. It is under the air box lid, next to the shifter. The wired connectors are connected to the frame by little clips. I'm sure you'll find it there, but you will need little finger to get it back on without taking the plastic off. I can get you a pic if you need it. Let me know.
Old May 22, 2002 | 09:36 PM
yah i know what your tlaking about.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
