Premix ratio
Old May 15, 2002 | 10:04 PM
Some1's Avatar
Whats the best ratio to run in a 1986 250R? It's bored out to 310cc and has just finished being broken in.
Old May 15, 2002 | 10:07 PM
Thrust's Avatar
Depends on your compression. You should be able to run 40:1 or 32:1 perfectly fine in a 250R. I've heard both,that 40:1 is better then sometimes 50:1. Do you know your compression numbers?
Old May 15, 2002 | 10:10 PM
Some1's Avatar
Also, does a paticular riding style require a certain ration. Say, trail riding, whats the best ratio for that. I'll still have to check compression
Old May 15, 2002 | 10:14 PM
Thrust's Avatar
Probably 40:1
Old May 15, 2002 | 10:18 PM
Thrust's Avatar
I don't think it matters for certain riding situations.
If its tight slow trails. The 250R will NOT be happy going slow.
I still think the best is 40:1.
Old May 15, 2002 | 10:20 PM
Thrust's Avatar
Buy yourself a ratiorite that'll tell ya.
Old May 15, 2002 | 10:21 PM
2fun's Avatar
Depends on the oil.
A high quality synthetic can be ran at higher ratio's and still provide as much, or more protection than the conventional oils of yesteryear.
Two mixes that I have used, and am happy with performance, and protection wise;
Golden Spectro 40:1
Amsoil 2000 fully synthetic 50:1
Old May 15, 2002 | 10:29 PM
Thrust's Avatar
Well I was half right.
Old May 16, 2002 | 10:23 AM
briansgi's Avatar
I also run a 310 kit and I run Amsoil 2000 at their recommended 50:1 ratio, I haven't had any problems. Whatever oil you choose, just pick a good quality oil and stick with it.
Old May 16, 2002 | 07:22 PM
ltracerx's Avatar
I will swear by Golden Spectro. I've been on the same plug for about 6 months. I use to mix at 50:1, but I am in the process of breaking in my top-end so I am using a 40:1 mixture and richer carb. settings, but still haven't fouled the plug(knock on wood)
