oil change?
Old May 16, 2002 | 10:43 PM
gtx's Avatar
gtx
I just changed my oil for the first time. The dealer had already changed the breakin oil before I bought it. Anyhow when I pull out my oil filter the left side of the crank case it has metal filings on the filter. Is this a problem or is some filings expected because of being gear driven?
Old May 16, 2002 | 11:10 PM
YoDaddy's Avatar
Its normal for the first couple of times. Nothing to worry about. Thats why those first oil changes are so crucial.
Old May 16, 2002 | 11:17 PM
Alaska400EX's Avatar
Yeah, shavings for a couple oil chnages here too. I seemed to have more in my transmission side though. Nothing to worry about, just keep changing your oil regularly and you will be fine......JIM
Old May 17, 2002 | 12:05 AM
Derno24's Avatar
An add on to this question. What kind of oil do you use Synthetic, Synthetic blend, or just regular oil and what weights.
Old May 17, 2002 | 08:08 AM
gtx's Avatar
gtx
klotz racing oil and maxima transmission oil(my dealer used). This is the first time I have changed the oil. I used the same. I also had a hard time getting the metal oil filter by the rear shock, needing some suggestions.
Old May 17, 2002 | 10:06 AM
Sandgod's Avatar
I'm with ya GTX on the filter by the rear shock. What a biatch. Suggestions anybody? I use Valvoline synthetic blend and thier 80-90w gear oil....
Old May 17, 2002 | 12:37 PM
Cannitor's Avatar
if you change your oil and clean your filters every other ride you really dont need to clean the filter by the rear shock
its a coarse filter,not a fine filter
the last time i cleaned mine it wasnt even dirty
if im not mistaken its also a return filter so in theory the oil should already be filtered prior to reaching this area
somebody correct if im wrong here...
Old May 18, 2002 | 02:38 PM
jcv400ex's Avatar
Your right. As long as you change your oil regularly, your okay on the rear filter. The only trick I've found, cut a cheap 14mm wrench in half. This gives you alot more room in there to turn a wrench on it. I'm just going to pull mine every 6 months to clean it. I think this will be sufficent.
Old May 18, 2002 | 09:35 PM
KNOWSALOT's Avatar
The Facility
We run Honda HP4 20W50 in the engine and Honda 80W Transmission oil in the trannys.
I agree with the majority here on the rear filter issue.
Old May 27, 2002 | 03:45 AM
NittroT's Avatar
How do you guys clean the metal shaving off your filter?
