what do you run for tire pressures??? HELP
I have a stock 2002 400EX and i weigh 235. what do you think i should run for pressure in tires??? do i put same in front as back??? the dealers said put 5 psi, but i have heard of guys putting as much as 10 psi??? let me know what you all run....i still have stock tires if that means anything. THANKS
Woods racing and motocross here.......3 to 5psi max.
Be careful with experimenting with high air pressures. If you put enough to "round" the profile of the tire and leave it there for more than a day or two, the tire will never go back into it's original "flat" profile. This applies to all Ohtsu tires that come as stock equipment on the Honda's.
I stock Honda tires, we run 4.5 on the fronts and 4 on the back. The difference in your weight and the average rider isn't more than 70 lbs so you wouldn't need to adjust air pressure by more than 1 lb.
I like a little more in the front to stop tire roll.
/NotuRaptor
/NotuRaptor
