Any body running duglas rims on 650?
Old May 26, 2002 | 09:27 AM
ROWDY's Avatar
The lady at rockymauntain told me that the center hole was to small for 650. So I ordered itp c series same price but they are on back order. You know it took me 6 months to decide to get wheels and tires now I dont want to wait. It is like that roll of film I had in my glove box for a year when I took it in to have processed I wanted it back same day.
Old May 28, 2002 | 12:37 PM
ROWDY's Avatar
no one here has douglas?
Old May 28, 2002 | 09:07 PM
nyroc's Avatar
Yeah I just got 4 douglas rims for my 650. I put my mudzillas on them. I got 12x8 and 12x6. I bought them from tread depot, http://www.treadepot.com
I haven't put them on the quad yet. What did you wanna know? Want me to put one on and make sure it fits? Your question has me concerned enough to go try it.
I like them due to the spacing and the widths they have. I did not like the c series spacing or widths.
They are thick too.
Old May 28, 2002 | 09:40 PM
ROWDY's Avatar
Could let me know if they fit? I hope for your sake the lady a rockymountain was wrong. Thanks
Old May 29, 2002 | 01:04 AM
nyroc's Avatar
Yeah they fit. It was really easy to mount the tires, but hard as heck to bolt the wheels on.
The center hole is exactly the right size, the bolt holes were not drilled with quite enough clearance, so it is hard to push the rim on. I have the front left one on. See this picture for proof that they fit.
It took a yank to loosen the wheel, then I spun it 180 degrees and gave a second yank and it was loose.
So, they aren't bad wheels, they just fit a little tight. The threads on the lug bolts are filing down the holes where they need it, so it will be easier next time.
Old May 29, 2002 | 09:16 AM
trx450's Avatar
A note about the ITP "C" series wheels: The Kaw.P-650 "C" series lug holes are counter bored deep into the casting. You need to buy smaller diameter lug nuts(14MM flats), in order to use a normal socket to install/remove same. While the stock lug nuts fit(I think), you would have to use an extremely thin-walled socket to run them on/off the lug! The replacement lugnuts are cheap, $3.50 for 16 @ Rocky Mtn. ATV, don't forget to order them when you order your "C" wheels.
Old May 29, 2002 | 11:19 AM
DUstanko's Avatar
Maybe this may help. I too read these forums for a few months before deciding on tires. The first place I called was Rocky Mountain ATV. Their prices were incredible but they had backorders on the Gators.
The lady in question is actually the owners' mother. I believe her ATV knowledge is that from learning experiences in taking in customer calls for products. That and having a manual or two by her She was giving me a run around about 27" tires being too being too much for my 650 without a lift. To me it does not sound like Rocky Mountain has the overall tech advice like a Highlifter, but you can't beat their prices. I ended up buying from EastKY as the prices there for Gators were very good.
Daryn
Old May 29, 2002 | 12:35 PM
KevinDevitt's Avatar
Hi ROWDY,
Still around I see. Lets get together for a ride sometime. How do you like the 650?
KD
Old May 29, 2002 | 12:49 PM
ROWDY's Avatar
THANX nyroc sound like she gave some bad info.
KevinDevitt
I love it. Dude we have to get to gether and ride sometime. It is in the shop thought I had a pin hole in rad but the said tighted up and pressure tested fine. I cant go riding this week end on call lets go any other time.
Old May 29, 2002 | 03:13 PM
nyroc's Avatar
I just put all 4 douglas wheels on. They were a little hard to push on, but they are fine now after the wheel studs rubbed the holes a bit.
They cost me $69 ea for the fronts and $74 ea for the rears at treadepot.
Bigredjeep
Apr 10, 2020 02:55 AM
Dame0927
Oct 29, 2015 10:13 PM
WilliamBos
Sep 30, 2015 08:08 AM
TLC
Jul 1, 2015 08:29 AM
outlaw2006
Jun 28, 2015 10:30 AM
