Proper chain ajustment?
Old Jun 12, 2002 | 08:59 PM
Tom8456's Avatar
Just put a new chain and sprockets on. Was wondering if the chain should be ajusted with the rider on the atv. I noticed that the tention of chain changes quiet a bit with the rider on it.
Old Jun 13, 2002 | 05:04 PM
fuddrucker's Avatar
This is one of those questions where everyone has their own opinion. Some will say with a rider on the bike, others say no rider. Then some will tell you to adjust it with the back wheels off the ground.
I personally adjust the chain with someone sitting on the quad. Like you said, when someone is on it, a lot of the slack is taken up. When I changed my sprockets and chain, I was wondering the same thing. I did a search of this forum and found a lot of posts on the subject and most agreed that one should adjust the chain with a rider on it.
HTH.
Old Jun 13, 2002 | 10:05 PM
GTV's Avatar
GTV
To tight, the chain puts an astronomical amount of stress on the counter shaft and rear bearings(rear bearings are week on the ex's), to loose, well, I haven't had a problem with to loose yet but it could present a problem, if the chain came of on a 75\80 degree hill !!! You choose!
Old Jun 13, 2002 | 10:35 PM
powerslider's Avatar
Compress the suspension until the swingarm is parallel to the ground, then adjust the chain, this is the tightest position it will be through the arc of suspension travel.
Old Jun 14, 2002 | 01:31 PM
Tom8456's Avatar
Thanks for the info I think I'll try ajusting it with the rider on it. Thanks for the replies.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
