Stuck shock adjustment nut!
Old Jun 13, 2002 | 09:17 AM
02BAJA's Avatar
I need to adjust the sag in my rear shock. So big deal, but when i went to do the adjustment the lock nut wouldnt budge! You have to turn it counter clockwise right? How can I get this thing to move? Anyone else have this problem? Thanks.
Old Jun 13, 2002 | 01:00 PM
Hightower's Avatar
Yeah, loosen the locknut counterclock, then adjust the nut against the spring as needed. Its hard to get a spanner in the tight area - one that fits a ratchet works best. My locknut was really tight too - had to bust it loose with a couple hammer blows against a brass punch, so as not to mar the nut all up.
Old Jun 13, 2002 | 01:26 PM
02BAJA's Avatar
I hit on it last night! I guess I will have to use a bigger hammer!! [img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 13, 2002 | 07:39 PM
DemonDS's Avatar
See if you can find a way to compress the spring. I used a rachet strap anda jack to do mine. use the strap to hold the compressed spring and then the jack to spread out the quad again. you can easily adjust it then. sounds complicated but think about how it all works and you'll see what I mean.
Old Jun 13, 2002 | 10:20 PM
Hightower's Avatar
Demon - I think the complication is from the lock nut, above the adjuster nut - he can't get it loose.
Old Jun 13, 2002 | 10:48 PM
DemonDS's Avatar
Yah I know, I had that same problem. I beat the heck out of mine and it would not budge, even with WD40. Thats how I finally got it loose so I could finally adjust the adjusting nut. I think it just had the pressure through out the whole thing if you know what I mean.
Polaris5
Aug 29, 2015 09:11 PM
Stever6368
Aug 16, 2015 07:34 PM
Polarisman1123
Aug 13, 2015 08:13 AM
Mssarabug
Aug 10, 2015 12:56 PM
07Redrider400
Jul 25, 2015 05:31 PM
