700 Needle Clip Round 2
Old Jun 15, 2002 | 10:32 PM
SpruceDuece's Avatar
A little history....
I installed a K&N airfilter and lost midrange. From 1/4 to 3/4 throttle from a stand still, the wheeler would fall flat on it's face. I posted the question as to why and did a little research myself and decided that the needle clip needed to be moved. With the stock air filter back on the machine was strong as normal.
Today I took the carb off and moved the clip down the needle(toward the tapered end). It was in the fourth notch and I moved it down to the fifth(last) notch. Now it really sucks. If you jump on it even a little it nearly quits.
Did I move the clip the wrong way? Is the clip not the issue. I was really careful to make sure the rubber diaphram was seated right. I hate bringing stuff to the shop "in a box" for the professional to "fix".
Additionally, I screwed up the idle. Anybody know what the factory idle is supposed to be.
Thanks for any ideas.
SpruceDeuce
Old Jun 16, 2002 | 03:24 PM
Problem solved. I didn't have it put back together quite right. Thanks to the diagram at partsland.com
SpruceDeuce
ReconBayou
Oct 16, 2019 02:24 AM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Sep 2, 2015 11:15 PM
