brake line fittings
Old Jun 24, 2002 | 04:25 PM
northjeepster's Avatar
Just thought to ask if anybody knows what size is the banjo fittings at the master res. and the brake calipers. Also what is the size of the banjo bolts. Does any know what sizes they go by I have a racing supply near me and im preping my ds for racing I already bought the rear braided steel line from ebay and what to convert my front brake lines with steel braid. Im also thinking about converting my coolant and oil line to steel braided. I what to make this thing into a tank!!!
ps Not to sound stupid but I know it's from canada and everything is metric lol heha.
Old Jun 24, 2002 | 05:17 PM
back to top
Old Jun 24, 2002 | 07:13 PM
top
Old Jun 24, 2002 | 10:14 PM
top
Old Jun 25, 2002 | 02:27 AM
I thought you guys would know this! whats up!!i know its not the most popular subject like pipes and engine kits. Do any of you guys know anything about braided hose used for engines!! I sorry if i sound like im mad but not one person replied even if they didn't know the anser[img]i/expressions/face-icon-small-shocked.gif[/img]
northjeepster
Old Jun 25, 2002 | 03:01 AM
jeffnrivercity's Avatar
OK,OK,OK.....
But I can't answer your question,I think
I have bought front braided lines from timmyboy for my Baja.(2 line design)
I had front ones made for my DS760(single line w/split),just took the old ones in and told them to make them 2"longer then the stock set up.
I made my own rear,but took the old line in and had them match the fittings
I was told that the banjos & bolts were a common size used on most bikes(the banjo bolts are all the same from calipers to mastercylinders)
On the braided coolant hoses,I tried to put them on but the long bottom hose wanted to kink(so I put the stock one back on)so I have the upper line braided.the short one off the water pump would be impossible(unless you use the braided look covering)
I do plan to do the oil lines,just havent got around to it(they should work with out kinking
Good luck
Jeff
Old Jun 25, 2002 | 02:36 PM
heh thanks that all i whated to know thanks
northjeepster
STLyamwar
Jul 25, 2020 04:44 AM
ronnierhino06
Nov 9, 2015 12:56 PM
MikeyBoyesq
Aug 10, 2015 11:11 AM
Stirling
Aug 9, 2015 01:49 PM
SixSpeed5
8
Aug 2, 2015 05:38 PM
