question for anybody with aftermarket exaust
no matter what jetting setup i have doen, i cannot get it to stop popping out of the silencer. sometimes it is a loud back fire, or sometimes it is a quiet little pop. could it be my exaust is not on all the way? i ran it rich, i ran it lean and it still makes the same noise. IT is a GRaydon full exaust, could the popping be from simply being a Straight flow exaust?? can someone please help me.
Usually, 9 times outa 10, popping after letting off the throttle is due to a mal-adjusted idle mixture screw, which has to be adjusted anytime jetting and airflow is changed.
Turn idle mixture screw inward until motor starts to bog, then start turning outward - while counting every half turn - until the motor starts to bog again. Set the screw exactly halfway between the two points of bogging and the popping should be gone. Any time you change the main jet or needle position, or change your intake or exaust flow, this needs reset.
John Reed
Sep 9, 2015 03:46 AM
Logan Collins
Sep 5, 2015 08:03 PM
