The 2003 models
Old Jun 27, 2002 | 11:34 AM
727Banshee's Avatar
There on the C-dale site now
Old Jun 27, 2002 | 12:53 PM
727Banshee's Avatar
Did C-dale give there cannibal an extra 1000rpm cause on the specs it said they did: Cannibal Specifications
Engine Four-stroke single
Displacement 432cc
Bore & Stroke 95mm x 61mm
Compression Ratio 12.5:1
Valve Train DOHC, four-valve
Fuel System EFI, 11,600 RPM Soft Rev Limiter
Cooling System Liquid-cooled
Ignition System Constant-energy inductive coil
Starting System Electric Start
Compression Release Automatic
Lubrication System Dry Sump
Clutch Type Manual-Hydralic
Transmission 5-speed cassette, no reverse
Drive 2WD/520 O-ring Chain
Frame Type Aluminum, twin spare, perimeter
Length 73.5 "
Width 46.4"
Wheelbase 49.5"
Turning Radius 8'
Seat Height 32.5"
Ground Clearance 4.5"
Dry Weight 375 pound(not competition weight)
Front Suspension 9" travel
Rear Suspension 10" travel
Front Tire 21 x 7-10
Rear Tire 20 x 11-8
Front Brake Hydraulic, dual disc w/parking
Rear Brake Hydraulic, single disc
Fuel Capacity 3.2 gallons
Colors Silver w/ blue accents
Old Jun 27, 2002 | 01:37 PM
beyer05's Avatar
Is it heavier than last year?
Old Jun 27, 2002 | 02:58 PM
MxDale71's Avatar
Who knows... The weight has been such a big confusion that I don't think anyone even cares anymore. I've seen it say Dry weight 375 and in fine print it says all weights measured w/ all fluids... [img]i/expressions/face-icon-small-confused.gif[/img] I don't get it. I'm gonna have mine weighed one day and I'll let everyone know what it says.
Old Jun 27, 2002 | 03:14 PM
1986atc250r's Avatar
Only the limited edition 2003 cannibal is on the website. It's revlimiter is stated the same as last years - both of which are likely wrong.
I've looked into the calibration myself and the current cannibal rev limit is set at 10,800. The Speed, Blaze, and Moto are set to 11,500.
Weights are elusive... The Japs are really bad about posting very optimistic numbers, Cannondale posts theirs less opimistically. Hard to tell without actually measuring the quads side by side.
Old Jun 27, 2002 | 04:03 PM
beyer05's Avatar
Well, what makes it weigh more than a moto? Steel wheels this year?
Old Jun 28, 2002 | 02:13 PM
MrP's Avatar
MrP
When are the 03 models going to be released.
Mar 21, 2016 06:30 PM
Whitelx1
Oct 2, 2015 10:55 PM
Hw00d
Sep 10, 2015 08:53 AM
chewy78
Sep 8, 2015 10:37 AM
