Cannondale front sprockets.
Old Jun 28, 2002 | 11:54 PM
Sandgod's Avatar
I heard a 400ex front sprocket will fit a Dale. I bought one. WRONG.... What about the rear ones also. Anybody know of another manufacturers sprocket that will fit???
Old Jun 29, 2002 | 12:45 AM
1986atc250r's Avatar
I know for a fact that the 400EX rear sprocket will work. Not sure of any other applications that will work for the front.
Old Jun 29, 2002 | 03:36 AM
jcv400ex's Avatar
A front sprocket for a KTM will work. I'm planning on trying a 14 tooth front, and a larger rear. It's going to be tough to find a larger rear sprocket though......400ex sizes only go up to 39 teeth. Might have to look at having a custom sprocket built.
With the larger front, it should cut down on chain wear and the slider. If you want to really get radical, a KTM 520 comes with a 15 tooth front. You'd be almost pushing 100mph then with the stock rear sprocket!
Old Jun 29, 2002 | 08:11 AM
dawzie's Avatar
I'm running 15x39 for mx C-dale for the front, Honda works on the back
Old Jun 29, 2002 | 10:35 AM
Sandgod's Avatar
Thanks. I have a 39 rear off a 400ex. I am maxed out in second going up Sand Mtn, but can't pull third. Meeting some guys today on DS's and Raptors from here. "Whispering in a very quiet voice" I got to gear up so my 432cc will pass the 650's and 660's on the hill and in the big bowls. heheheh[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jun 29, 2002 | 01:45 PM
haulin's Avatar
What are the stock sizes on the cannibal, speed? 13/?
Old Jun 29, 2002 | 02:00 PM
Old Jun 29, 2002 | 02:55 PM
smitty911's Avatar
All,
So if you went with a 14 front what will the back have to be to stay around stock gearing? Will this decrease the wear on the chain slide?
Any ideas?
Smitty
Old Jun 29, 2002 | 03:05 PM
Gearing calculator
Yes, it would reduce wear on the chain slider
Old Jun 29, 2002 | 03:31 PM
smitty911's Avatar
Thanks for the link. That should help alot.
Later
Smitty
