Question on trailblazer shock.
Old Jul 1, 2002 | 03:01 PM
craustin's Avatar
I have a 2001 trail blazer that is having a slight problem with the right front shock. The spring on the shock is a little loose. By this I mean that you can rotate it with your hand. I tried tightening the top bolt on top of the shock, but it does not tighten. When I ride it tends to rattle, and vibrate along with the motor. Any ideas on how to fix it? I can see 4 threads on top of the nut that you tighten on the shock, and if I tighten it (while holding on to the part that turns) it still dosent tighten. I an stumpted, any help would be greately appreciated.
Old Jul 1, 2002 | 07:59 PM
x_scrambler3's Avatar
you need to take off top bolt pull the shock an spring from frame an there is another nut in there that has a half moon peice of plastic around it you need to tighten that one
Old Jul 1, 2002 | 11:56 PM
craustin's Avatar
Thanks a million, will try this weekend>
shimanok2
Jan 29, 2016 07:37 PM
bigred20653
Oct 2, 2015 10:05 AM
2many2ride
Sep 27, 2015 04:35 AM
bigred20653
Sep 19, 2015 02:11 PM
chewy78
Sep 8, 2015 10:37 AM
