spark plug - can I damage my engine!
Old Jul 3, 2002 | 07:28 PM
stuckinmud's Avatar
I was told I can use a NGK BKR5E in my 2001 Trail Boss. It is said this plug will perform better for trail riding. Is this true? Will I cause any damage to my piston or valves if this plug would happen to create more heat than the recommended plug?
Thanks!
Jeff
Old Jul 4, 2002 | 11:27 AM
92LT's Avatar
I don't own a trail boss, so I can't give you exact answers.
What is the stock spark plug number? Is the trail boss the 250 2 stroke or the newer 325 four stroke? There are several guides online where you can check out what each number/letter means on the spark plug. I think I saw a good guide on macdizzy's site. Just by changing the spark plug it would be doughtful that you would see any performance gains.
Old Jul 4, 2002 | 10:00 PM
XtremeV6's Avatar
Last time I had my Scrambler serviced, they put a BKR5E in it (it is supposed to be a BKR6E). The BKR5E is a hotter plug better suited for trail riding where it might get wet. I have just installed the airbox mod, exhuast, clutch kit, and carb mod and switched it to a BKR7E. This plug runs cooler, better suited for higher RPMs.
Old Jul 4, 2002 | 10:34 PM
archerr2002's Avatar
Jeff, that is the exact same plug I run in my 01' Trail Boss. I have had it in there for over a year now and no problems at all. My Boss is modded pretty good. K&N air filter,air box mods, White Bros E-series and clutch work just to mention a few. You should have no problems with the BRK5E.
Work to live, live to ride!!
Hankey Pankey
26
Oct 18, 2020 03:50 PM
WilliamBos
Sep 30, 2015 08:08 AM
02Chevrolet
1) Engine problems..
Jun 23, 2015 12:12 AM
joshuafromny
Jun 22, 2015 05:30 PM
Ask the Editor
Jun 3, 2015 04:16 PM
