Do I need an Engine/Oil Heater?
Old Jul 4, 2002 | 11:49 AM
Nordikwolf's Avatar
I Have a Magnum 325, which I store outside. Does anyone know when it would be prudent to install an Oil Heater for Cold-weather starting. As I'm unsure if my location (within 100 miles of NYC) would be a wise expense. On the other hand, since I plan to use the snowplow it would be EXTREMELY UPSETTING if I couldn't get the bike started!
Old Jul 4, 2002 | 07:41 PM
Elrancho's Avatar
Fresh gas in the winter helps carbs a bunch, for oil a synthetic oil in the winter makes cranking on the order of 20x easier over "hardened" normal motor oil... it'll do more than a heater on normal motor oil.
Old Jul 5, 2002 | 10:09 AM
Billyclub's Avatar
Plowed last winter in some very cold storms and do alot of ice fishing in extreme weather. The Sportsman has never let me down yet, she was a little sluggish starting at 10 below zero but after a couple starts the choke took over and I was off and running. Best advice I have is change ALL the fluids before the onset of winter and you should'nt have a problem. This removes any condensation and water and thus keeps the fluids from freezing and breaking down.
Old Jul 12, 2002 | 09:27 PM
Elrancho's Avatar
That "a little sluggish" is almost always from thick oil, not cold batteries.
Old Jul 13, 2002 | 02:23 PM
Billyclub's Avatar
so whats you're point
Old Jul 13, 2002 | 02:25 PM
Billyclub's Avatar
So what point are you trying to make?
shimanok2
Jan 29, 2016 07:37 PM
mdrkcckv
Jul 22, 2015 09:10 AM
PolarisIce
Nov 11, 2004 12:37 AM
wes250
Aug 7, 2003 08:28 PM
robeze
May 27, 2003 12:24 AM
