anyone think a double radiator would work for overheating
Old Jul 7, 2002 | 11:47 PM
maximus's Avatar
i came buy 2 junked out 350L wheelers this weekend. was toying around with the idea of taking the radiator out and pluming it in to my radiator to help with extra cooling, to keep from overheating. i was thinking of doing this are taking out the fan and riging up 2 fans. which would be better. also has anyone tried taking off the side panels and screen for more airflow. would this be better are worse for overheating etc. mud getting in. i carry around a bulge pump to clean out radiator.thaks just kicking around some ideas
Old Jul 8, 2002 | 12:28 AM
yamahagye's Avatar
If there is enough room for 2 radiators, I think it would help quite a bit with cooling. If you are running two electric fans, you might be draining your battery faster than it can be charged (I'm assuming that it has a battery).
JaMeS
Old Jul 8, 2002 | 12:45 AM
maximus's Avatar
the bike i have has plenty of room for the extra radiator. i wander if my water pump will be stong enough to run through 2 radiators. i am going to do one are the other not both.
Old Jul 8, 2002 | 03:43 AM
yamahagye's Avatar
I think your water pump will be fine. Just have it set up so the water is pumped out of the head(like stock) and then travels to radiator #1..Instead of having the water pumped back into the head, it will "flow" into the next radiator. The the water will be returned to the head. The pump will be pumping the same amount of water at a time, so there will be no extra work to do.
JaMeS
Old Jul 8, 2002 | 11:35 AM
maximus's Avatar
i might try it and see how it works. it would be great if it would.
Old Jul 9, 2002 | 03:47 PM
maximus's Avatar
i have made a bracket now that bolts the radiator to my front split rack. looks great. looks like part of the bike.anyway just got back from the auto parts store with some extra hose and fitting to make it work. will try it out and see how it works. seems like it will work.
Old Jul 11, 2002 | 02:48 AM
yamahagye's Avatar
Be sure to let us know how it works.
JaMeS
hugemoth
Jul 20, 2020 03:28 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
