Double barrel pipe
Old Mar 14, 2000 | 12:13 AM
Joe304's Avatar
I just put a DMC Double barrel pipe and a ProFlow filter and a 150 main jet on my 95 Warrior and when I let off the gas it backfires and shoots a flame out the pipe. What should I do?
Old Mar 14, 2000 | 03:23 PM
sAyIt_fmf's Avatar
Alot of the four strokes I have seen with cam work or heavy mods do backfire a bit when letting off the throttle after hard runs... But it is not normal to be shooting serious flames out the back end.
I would check with the manufacturer of the pipe to see if your close with your jetting.How does the plug read? Black?
If the jetting is OK , then I would start looking into timing..(valves,etc.)....Unless the exhaust system you bought does not have a spark arrestor... If it is a strait through pipe...It is possible that it is normal(at least the flames)....But there should not be alot of backfiring.
Old Apr 12, 2000 | 06:04 AM
Air's Avatar
Air
Go up one or two sizes on the pilot jet
Old Apr 12, 2000 | 08:51 AM
boomer's Avatar
Richen up your air screw by turning out in 1/4 turn increments. Your running lean on that circuit. If you get more than 4 turns out and the problem is still there, then go up 1 size on your pilot jet and start the same process again.
Old Apr 12, 2000 | 04:47 PM
RoostKing's Avatar
Keep the flames, thats way better than roosting someone!!!
RoostKing
Old Apr 12, 2000 | 11:37 PM
86atc250r's Avatar
No, no, no folks.....
Lean jetting does not cause backfire and flames on deceleration, period.
It is caused by a rich condition. A lean condition WILL cause backfire on ACCELERATION, which is a very bad condition and should be taken care of immediately.
Think about this..... Modern fuel injected cars have a deceleration routine that cuts the injector pulsewidth on deceleration for mileage and emissions reasons, which causes a lean enough condition to actually cause the engine to "die". They refire the engine at a predetermined point, or when the throttle is touched, with a little extra rich mixture so that it goes un-noticed by the operator.
With this in mind, what was the last vehicle on the road you heard backfire on deceleration, the brand new Lexus, or the old Ford pickup with a Holley, glasspacks, and reeking of unburnt fuel? Also, how would a lean condition cause flames to shoot out the exhaust???? Fire is caused by extra fuel not the lack thereof.....
If you would like a little more explanation, check out this link on: Dejanews
mrtidy
Feb 3, 2016 05:00 PM
ltzbrad
Sep 25, 2015 05:52 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
greg86hd
Sep 16, 2015 12:32 AM
bvolks
Sep 13, 2015 12:57 PM
