clamp on k&n's
Old Jul 11, 2002 | 10:20 PM
yfm660r's Avatar
what are the part numbers for the clamp on K&n's that fit onto the raptor carbs. Please help me, come on... i said please
Old Jul 11, 2002 | 11:05 PM
desracers's Avatar
You could go down to auto part store and get the hose clamps and it would be a lot cheaper to get it and you don't have to wait for the order to come in.
That what I would do......
Bill
Old Jul 12, 2002 | 12:59 AM
XtremeRaptor's Avatar
I read somewhere else in this forum that the clamp ons won't work on the Raptor because of the carbs being too close together. Not sure though, so you might want to check with some of the other Raptor owners on this forum with more experience than me. Later Xtreme
Old Jul 12, 2002 | 05:53 PM
Ward660R's Avatar
You can't get K&Ns to clamp onto the carbs, they are too close together. I ordered two K&Ns with the 10 degree angled neck thinking I could turn them just right to make them fit, they wouldn't. So I already had the Pro Design foam filter on in my stock air box, I just cut the air box off of the flange in the front and put the filters on it. It works alot better now. You could do this alot easier by using a thin peice of metal, that bolts to the holes where the pegs in the air box go, and then welding two lips on it. I think that the rear end of the velocity stacks coming off the carbs are 2.5" so that is the size lips to weld to it. Then order your K&Ns with the same size opening as the lip and there you have it. This way, in theroy acutaly works better than on the carbs because using the velocity stacks speeds up the air before it hits the carbs. If you do this check to make sure the size of the opening on the velocity stacks first, I might be wrong on that.
Old Jul 12, 2002 | 05:56 PM
vilnrk's Avatar
If you did mount K&N's directly to the carbs, how were you going to route the 1/2" lines that connect into the tops of the carbs???????
Old Jul 12, 2002 | 07:01 PM
Ward660R's Avatar
You know for some reason that never crossed my mind. I guess that I am glad it didn't work.
Old Jul 12, 2002 | 08:50 PM
yfm660r's Avatar
what r those half inch lines anyway ? and the 3/8's ? line in between the carbs ?
Old Jul 13, 2002 | 11:53 AM
vilnrk's Avatar
The 1/2" lines control the slides. I've had my carbs off and checked them out. You can blow into the line and the slide will raise. Kinda weird how it even works, but it does. The little line that runs between the carbs is just the bowel vents.
Surly there is some CV carb guru on here that can shed some light as how these slides operate. I would think that the 1/2" lines would operate off of the vacuum since they are connected to the inlet side of the air intake.
[img]i/expressions/face-icon-small-confused.gif[/img]
STLyamwar
Jul 25, 2020 04:44 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
randymack
Aug 24, 2015 05:47 AM
toonces
Aug 13, 2015 01:48 PM
