Will 26 inch gators fit under a 450S on stock rims with out rubbing
Old Jul 15, 2002 | 11:52 AM
DanimalFL's Avatar
or do i have to lift it
Old Jul 15, 2002 | 12:03 PM
RINCON's Avatar
my brother just put on 26" 589's and they don't rub. the black plastic up front where it wraps around to the headlights, right on the corner, almost hits when you compress the suspension, but it doesn't. I've heard a couple people had troubles with the rear drive shft going out on the 450's with lifts
Old Jul 15, 2002 | 01:28 PM
oleyella's Avatar
I have a 450es and I put 27" 589's on my stock wheels,I ride double 99% of the time and I've never had a problem hitting or rubbing.
Old Jul 16, 2002 | 01:43 AM
scosho's Avatar
I put 26" Dirt Devils which have tread about 2" deep under my 450S. These added height and a lot of width, about 4" wider in back. The tires clear all body, frame and suspension on stock rims. I got the same top speed on the speedo, which is actually faster because of the larger tire diameter. Steering is noticeably more difficult, and it was pretty stiff to start with. Traction is awesome, and nothing sharp has found its way through the 6 ply tires yet. I say lift away.
STLyamwar
Jul 25, 2020 04:44 AM
TLC
Sep 5, 2015 12:49 PM
XxS0ccerstarxX
Aug 27, 2015 02:31 PM
Cantbuytime
Aug 17, 2015 06:33 PM
Jul 23, 2015 07:53 AM
