43 tooth rear
Old Jul 20, 2002 | 11:58 AM
sixsixT's Avatar
Have any of you used a 43 tooht rear sprocket on a raptor with the 13 tooth front? Will the stock chain fit? If not can links be added to chain or will I need to buy a new one?
Old Jul 20, 2002 | 05:43 PM
660bigdaddy's Avatar
i've got a 42 on mine. one option would be dropping a tooth on the front to a 12. just about the same ratio (12-40 is 3.33 and 13-42 is 3.30, stock is 3.07) and cheaper. i race in the woods so i run a 12-42 combo. that way i'm mostly in 2nd gear instead of always havivg to shift from 1st to 2nd with the stock set up.
good luck
Old Jul 20, 2002 | 08:21 PM
sixsixT's Avatar
Thanks for the input bigdaddy.I'm considering a 12 tooth c/s but thought it would be better to go bigger on the rear.And it's not much more money if I can use my stock chain. 13/42 is 3.23, 13/43 is 3.31, and a 12/40 is 3.33.
Old Jul 20, 2002 | 09:50 PM
sorry bout the math sixsixt. i've been out in the sun too long today. i was using the stock chain with my 13-42 setup. good luck
Old Jul 24, 2002 | 08:14 PM
sixsixT's Avatar
Put on the 43 tooth rear sprocket. Fits with the stock chain and clears my PRM skid, but just by a hair or two.I've only rode it around my property so far but feels much better.
Old Jul 24, 2002 | 08:18 PM
BlueLeader's Avatar
I have 13/42 with enough room for proper chain slack.
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
