Sport Quads Discussions on sport quads.
Does anyone up&down shift w/o clutching?
Old Jul 29, 2002 | 02:47 PM
ScramblerXcitement's Avatar
I was wanting to know how many of you operate your machines like this, I was considering a revlock clutch and it does not disengage when up or down shifting. Anything replies are appreciated.
Thanks
Old Jul 30, 2002 | 09:16 AM
CBUS660R's Avatar
On full throttle upshifts, I will grab some clutch, but I also just stab the shifter and don't blip the throttle. On downshifts, I don't touch the clutch usually.
Old Jul 31, 2002 | 06:18 PM
Corpsie's Avatar
I make it a habit to use the clutch when upshifting.
I have usually put myself in a bog-down situation when downshifting,
so I rarely use the clutch.
Old Aug 2, 2002 | 07:39 PM
Chris142's Avatar
I don't use the clutch except to get moving.Including my quad,atc,Jeep,Scout,pickup and my 18-wheeler!
As long as it doesn't grind nuthing bad happens,you need to give it a little throttle when downshifting.
Old Aug 2, 2002 | 10:54 PM
newZman's Avatar
Won't this smoke you clutch plate sooner or later?
Old Aug 3, 2002 | 01:04 AM
Ryanstones's Avatar
I don't use the clutch much either.
If it feels good, do it.
Old Aug 4, 2002 | 12:46 PM
Chris142's Avatar
<< Won't this smoke you clutch plate sooner or later? >>
Do what?
Not using the clutch will make it last much longer.
It can damage the trans if you shift w/o letting off on the gas or force it.It takes a little practice to downshift,dont just downshift,you must raise the rpm's to match the lower gear.
Old Aug 5, 2002 | 12:12 AM
Need4Speed's Avatar
I wonder if I could rig up a Jake Brake to my quad [img]i/expressions/face-icon-small-happy.gif[/img] .
Old Aug 5, 2002 | 01:50 AM
Chris142's Avatar
A Jake break isn't very effictive without a turbo [img]i/expressions/face-icon-small-smile.gif[/img].So plan on that too!
Old Aug 5, 2002 | 08:07 PM
bmbanshee's Avatar
i know a rider that doesnt use his clutch at all when we go to the mx track..its way to stiff..so its hard to pull that hag of a clutch in during a mx track..but ive just made it a habit to pull in the clutch when im both downshifting and upshifting..does it harm anything at all if you dont use the clutch while downshifting, because ive heard a lot of guys do it??
