unlocking a engine ideas.
Old Jul 29, 2002 | 07:07 PM
Yec13's Avatar
Hey,
anyone got anygood ideas for unlocking an engine??
thanks
Old Jul 29, 2002 | 07:20 PM
springboy's Avatar
what kind of engine. If its a high performance, u can hook a rope to it from another atv and drag it around with the clutch out. But the type of engine would be nice to know.
Hope this helps.
Old Jul 29, 2002 | 07:25 PM
Yec13's Avatar
im not much of a mechanic all i know is its on a early 80' hondA 90
Old Jul 29, 2002 | 07:26 PM
Yec13's Avatar
OM SORRY THE GAS TANK SAYS 90 ITS A 110 (I GET CONFUSED)
Old Jul 29, 2002 | 07:32 PM
springboy's Avatar
if it has a clutch try that. but if it dosent roll it down the hill and try to get the engine to turn over, but be careful it may crack the case.
But other than that its a main berring in the crank shaft i think.
Old Jul 30, 2002 | 02:03 PM
Yec13's Avatar
have you tried it? and if you drag it would you neeed weight on it??
and i dont know if its in nuetral it has a neutral indicater but its not working
Old Jul 30, 2002 | 02:12 PM
jcrcr254's Avatar
Spray some wd-40 or some kind of solvent into the spark plug and let it sit for a while then try what was said b4.
Good luck
Old Jul 30, 2002 | 02:15 PM
Yec13's Avatar
Ive heard that diesel works cause it dont evaporate as fast as wd40
but ill try that
thanks
Old Jul 30, 2002 | 02:17 PM
Yec13's Avatar
what other kind of solvents would be best?? unlocking a engine woill be cheaper than buying one
Old Jul 30, 2002 | 02:19 PM
Yec13's Avatar
would engine oil work???
