Sam Coe??
Old Jul 30, 2002 | 02:59 AM
Ds650RaCeR's Avatar
Does any one know how much the dang Big Bore Piston Kit from Sam Coe Performance is??
Old Jul 30, 2002 | 03:09 AM
jeffnrivercity's Avatar
Uninstalled prices
103mm Piston.................................$190.00
6mm stroker crank w/exchange.................$450.00
Bored 103mm cylinder new nicacyl w/exchange..$225.00
New Cometic head gasket.......................$29.00
Porting and valve job........................$300.00
Shim under kit with new HD valve springs.....$250.00
Old Jul 30, 2002 | 01:08 PM
14mins's Avatar
Jeff- do you know the Hp numbers for that???? 1500 does not seem out of line for that.
Old Jul 30, 2002 | 01:13 PM
I have no HP #'s.......
Old Jul 30, 2002 | 04:21 PM
BajaDS650's Avatar
How do you think the power from this would compare to a RWR Stage I kit?? And could both be used in conjuction with each other?? Thanx for the help.
2002 Baja DS650, modified end cap
Old Jul 31, 2002 | 02:28 AM
derbyking's Avatar
quadloco is getting this done.complete kit,cams,springs,porting,piston,cylinder,crank,shi m under bucket kit,everything.they should be working on his now so he might tell you.ill just say its alot cheaper than pami,ALOT! as far as hp numbers they never really said just told him a 16-18 hp increase over a piped and jetted ds,they did tell him it should smoke my 727 raptor im building,hehe,we will find out about the end of august.
Old Jul 31, 2002 | 02:50 AM
Ds650RaCeR's Avatar
ok thanx all
Old Jul 31, 2002 | 04:56 AM
mystereid's Avatar
It's official, I've been duning for over 30 years.
Does anyone know what displacement this combination would up the motor to? Thanks in advance.
Old Jul 31, 2002 | 06:53 AM
14mins's Avatar
myst- 103 piston =690
103piston + 6 mm strokercrank = 720
Did i pass the bombardie big bore test???
Old Jul 31, 2002 | 01:45 PM
BajaDS650's Avatar
$1500 dollars for a 720?? This doesn't sound too bad to me. Wonder how much it would all be to get it installed? Thanx for the help everyone.
I see mods in the future...............
