Just in !!!
Old Aug 1, 2002 | 04:18 PM
northjeepster's Avatar
Well guys after lots of reading I just got my Pro ciruct, dynojet kit, and my K@N. I'm also going to put on a proarmor rear skid plate and a rear steel braided brake line. I will probly run without a lid and put in 185 or 190 jets in the carb. I also have stainless steel screws for the bowl. I have dremel tool for backup on the old screws. The next things Ill probly go for are the full skid plate and 22 sport bandits.
Have you guys gotten any experaice gearing I would like to go in the 80mph range to start with 22/tires sugestions??
97 F-150 4x4
2002 rancher 4x4 ES
2001 ds-650
1970 Jeepster 33x12.5 lockers
Old Aug 1, 2002 | 09:04 PM
Hightower's Avatar
You'll break 80mpm with just putting on the 22" tires and leaving the gearing stock. Going to a 17T up front will take you higher yet, but you'll have to shave a little off the chain guard in front of the rollers to make it fit (at least I had to on mine;use dremmel). No chain mods are needed for adding the one tooth. Gearing up will cost you the drag race against the raptors because the holeshot will suffer, but if you're going for the long run, your top end will be fast.
With the mods you're adding, you'll soon want the CDI box for a higher rev.
With the rev box, I can break 80 with stock gearing and 20" tires, and still have all my low end, but I rarely ride anywhere I can open it up that far anyway.
Sounds like you got you stuff together well - all your adds sound good!
Old Aug 2, 2002 | 03:52 AM
thanks for the info hightower
