EPI black spring
Old Aug 2, 2002 | 03:16 PM
trbolvr's Avatar
Is the EPI black stiffer or weaker than the stock spring? How does it differ from the stock spring when riding? thanks
Old Aug 2, 2002 | 04:13 PM
jlpier01's Avatar
I would assume it is stronger, you could do a search for EPI on this forum and see how it has been discussed.
If you are going to do it youself, BE CAREFUL! Look at Nyroc's website for the how-to.
Old Aug 3, 2002 | 01:40 PM
trbolvr's Avatar
I use a secondary clutch compresser that a buddy made me. He coppied the design from a unit made for use on snowmobile clutches. It is very quick and easy to use. It's a litle big for the kawi clutch but it works.
Old Aug 3, 2002 | 03:16 PM
MJSTX's Avatar
Trbolvr: The black spring is longer and stiffer. It will give you better back shift on hills but will reduce your top speed a little. This spring is great for the P650 if you have larger tires. I am curius as to why you want to change to this spring? ........MJSTX
ReconBayou
Oct 16, 2019 02:24 AM
EIF
Apr 20, 2017 07:15 PM
buddieboy
Dec 9, 2016 05:50 PM
mongeon
3) General Discussions..
Oct 6, 2015 02:27 AM
Sassinm1
Sep 30, 2015 04:23 AM
